TwinTurbo.NET: Nissan 300ZX forum - Remove starter and rotate flywheel via crank bolt...
itsa300zx
on April 26, 2017 at 3:10 PM
Starter Grinds.... what gives?!?!
posted by FrozTTy
on April 26, 2017 at 02:11 PM
inspect flywheel through starter hole for broken or worn teeth first.
FrozTTy
14:11:27 04/26/17
Remove starter and rotate flywheel via crank bolt... -
itsa300zx
15:10:36 04/26/17
Should there be something between the tranny and the....?
FrozTTy
19:45:26 04/26/17
Are you running an N/A transmission with TT flywheel?
Doug71zt(CAN)
03:12:18 04/27/17
Oh jeez... you might be onto something.
FrozTTy
07:59:06 04/27/17
I was actually referring to something the size of the
FrozTTy
08:00:41 04/27/17
Re: I was actually referring to something the size of the
itsa300zx
11:14:26 04/27/17
Yes, that looks like the one, going off memory (n/m)
FrozTTy
12:27:17 04/27/17
The replacement starter, since used, may be hitting its
jzack
18:09:32 04/26/17
